(recovered from Airdata) came back in and formatted card. I got it again twice so came in again and changed the card for exactly the same make, model etc and no further issue. The cards I use are:
Does anyone have any more ideas or is there an application that i’m able to check the integrity of this SD card?
It was a bit chilly on the hands so a nice steaming brew back at the car was appreciated.
Had this on Mavic 3 with this old class 10 card did firmare update & started getting errors until i replaced with cheap U3 card from amazon & the problem never happened again also had the same issue with Avata. I loathe to throw anything away
@callum I think you are correct. I just hit the start button after installing it and that’s what came out. I have now read up on the operation of the app and can now confidently say that the attached image is the real one. Hopefully this makes more sense.I have taken the test a couple more times and they are about the same. (i don’t know what they mean but can confirm their similarities, which, i hasten to add are different / lower than the other card of the same breed.
Thanks for looking.
@callum
Yeah, new ones coming tomorrow.
There is a replacement called F3 but it’s far too complicated for me as it means going into Terminal and for me that’s a no no.
Cheers buddy
H2test is much better for catching cards with faked capacity as it writes the full disk size to check it doesn’t start overwriting data. It’s what you’d see on counterfeit cards that say 64gb but are only like 4 in reality.
I have had some success with this (https://www.sdcard.org/downloads/formatter/) and failing cards (short arms, long pockets). it may be worth a try. (benchmark before & after) still a risk that you lose something later though
