I bought an Air 2S off eBay which never arrived. While waiting I bought a hard case for it and made a custom 3d printed interior for it.
I then bought another Air 2S which did arrive in a Lykus hard case. Now surplus to requirements.
The Lykus cases are discontinued, the nearest equivalent I can find is the cheaper LEUKEFEE range on Amazon UK. You can get a brand new case for £45.
This is £25 and is barely used - the previous owner flew the drone less than 2 hours total. Plus £5 for carriage. Or meet around the Portsmouth area.
It will take up to 5 batteries - 4 plus one on the aircraft, an RC or RC-NI controller and battery charging kit.
Lykus Titan MA200: Built for the DJI Air 2S / Mavic Air 2 Fly More Combo with a standard remote controller. It holds up to 5 batteries, a charging hub, a charger, propellers, cables, and filters.
Key Features of Lykus Titan Cases
- Waterproofing: IP67 SGS-certified watertight and dust-tight rating. [1, 2]
- Material: Heavy-duty polypropylene exterior shell. [1, 2]
- Interior: CNC precision-cut high-elasticity EVA foam for shock and pressure absorption. [1, 2]
- Dimensions & Weight (MA210/MA230 class): Roughly 41.5 x 34 x 14.4 cm (16.4 x 13.4 x 5.7 in) with a net weight of about 2.1 kg (4.6 lbs)
