Hi Guys…just purchased the Evo 2 Dual Enterprise 640t…did all the firmware updates etc before first flight…i did a little flight to check all parameters were working then went into missions (which is why i bought it)…on going into the missions operations i didnt have any base maps with which to start planning the routes…anybody got any ideas what ive done wrong…
Regards from Terry
Paging @group-evo-2.
@Terry1 do you have maps available at the moment when flying normally? is it only in the mission planner that they vanish?
Thanks Guys…figured it out…if maps arent showing go into camera mode…go onto settings cog…drop down to the general tab and look for Mapbox…make sure the Mapbox is activated…which it wasnt on mine…Thanks all…regards from Terry
Thanks for sharing the answer Terry
