Avata 2 vision system calibration
Afternoon All
Anyone had an issues with Avata 2 vision system. I got the drone a little wet this morning only a splash and after 2 flights received vision system requires calibration.
Now it wont allow take off
Have you calibrated it?
Can’t figure out how as callibration does not show up in dji fly or on dji assist 2 consumer software
It looks like with the Avata 2 you cant calibrate the vision sensors
Do a firmware refresh and see if that gets rid of the error
Goog shout ill try that
No luck with that.
Ill have to send it off :frowning:
The vision sensors can be calibrated using the DJI Assistant 2 software on a computer (Windows & Mac).
You’ll need to connect thr drone to the computer via an appropriate USB lead.
Looks like that’s only the Avata 1, Jason @TheBinman
DJI suggest that auto-calibration is performed by the Fly app on the Avata 2:
Source:
