Avata 2 with NLD 2.5W Bi-Di Signal Booster/Amplifier
Hello everyone,
has anyone ever installed the NLD 2.5W Bi-Di Signal Booster/Amplifier (NLD 2.5W Bi-Di Signal Booster/Amplifier Kit v2 for DJI drones-nolimitdronez.com) in an Avata 2 ?
According to the NLD Discord channel, it should work. Has anyone here had any experience with it or can say anything about it ? On the NLD website, only the original Avata is listed. There, you have the option to choose an amplifier for either the FPV Controller or the Motion Controller. But the Avata 2 connects directly to the goggles, not to the controller (see picture).
Can’t say i’d ever heard of it until I did a quick search after reading your post.
Isn’t it easier and quicker to just use one of the many available hacks?
Sorry, I forgot the link :sweat_smile:
So far, I haven’t found any FCC hack or anything similar.
Just the method involving the empty file on the goggles (which didn’t make any noticeable difference for me).
Have you watched and followed @Mads-Tech Ians video?
I have noticed a difference
“Free ham file works but!”
Everybody else: Uh-oh. But what?
Glaswegians: That free ham file must really work!
You need Doc Brown to confirm it ;o)
giphy
Check out drone tweeks and drone hacks. Depending on software you can achieve the same without actually doing anything physical to the drone
The Ham file absolutely increases the RF output if you are in CE areas.
It’s a dramatic increase in RF power for CE users especially when in 5.8ghz mode.
If your not seeing a difference I would questions if it’s being done correctly or are you already in FCC area. The file must be saved in the specific way and placed onto the SD of the goggles.
Very simply to check if the ham file has worked go onto manual channel selection, set bandwidth to 40Mhz and check if you have 3 channels available.
If you have 1 channel you are in CE.
If you have 3 you are in FCC
The ham file only gives CE users more power as FCC already has full power.
So no benifit of using it with the dronetweaks app :thinking:
I’m sure I did it correctly. Once I’m back home from holiday, I’ll double-check it.
In my case, whenever I fly into or around a building, I experience signal interference very quickly. Even the range in open areas is only a few hundred metres.
Cheers Ian this is very useful (been a while since I watched the video)
Just checked my A2 and Neo and all good (a year after adding the Ham file)
I can try that with the channel later, I brought it with me.
Do the motors need to be running for that? That’s something I haven’t quite understood yet.
No just drone/controller/goggles
Alright.
I’ve read that the order in which you power on the devices matters. First the goggles, then the controller, and finally the drone.
Only when applying first time I believe
@Mads-Tech Ian, can you confirm?
Correct, when you put it on the card reboot the goggles with the file on but after that boot has zero impact.
Thank you very much for your support. I’ll check right away.
Does the mode (N, S, M) make a difference?
Im pretty sure like all the DJI stuff it starts up in Normal anyway
I’ve just checked. On 5.8GHz I have 3 channels available.
Does anyone have any idea what else could be causing the limited range?
I’m used to something very different from my Phantom 4 Pro :grinning_face_with_smiling_eyes:
