Hi,
Downloaded updates for Mini 4 Pro so its ready for a flight once weather picks up and Im not so ill.
The question I have is that dji controllers can easily start flickering on 4th green light after a flight. When I charge batteries I always charge remote up due to this… What green light on transmitter am I safe flying with, ie 3 lights, 2 lights blinking or am I best just charging it everytime to make sure no lights are blinking?
your safe to use it till its almost dead tbh, lowest should be 10-15%
@Wadda-C2 Depends on how many flights you are going to be doing away from a charging source Rich. The RC2 will last about 3 hours of normal use but I personally tend to charge my RC2 up before I go out if I intend to use all the drone batteries up in a session. I have an Anker portable powerbank with me as a backup if it gets low anyway.
It’s generally recommended not to drop below 20% battery charge but the RC has a Lithium-ion battery so charging patterns shouldn’t be an issue for battery health longevity.
The manual says to fully charge the remote controller before each flight.
The remote controller has a sound alert when the battery level is low so its a matter of inconvenience if your running out of juice before you intend on finishing a flight.
Fully charge the battery at least once every three months to maintain the battery’s health.
