40A ESC yeah?
that’s the mounting @Steviegeek
I run a AT2310 2200KV >info<
with a 6x4.5 bi-blade prop, so this should suit your motor also
I use a F35A ESC >info<
but any decent 40A ESC (BLHeli-32) should suit but make sure you have plenty of air cooling through the fuselage.
won’t need the cross bracket, motor will bolt straight to stock plastic motor mount
I meant for the prop end not the motor.
So what prop should he get?
Thanks for all your help!
but I’m not 100% sure it fits that prop adaptor, measure it before buying, the shaft needs to be 5mm
