I have recently bought a flysky receiver module fkysky FS-i6AB to experiment with my Flysky Tx.
How ever the flysky Tx was original bind to a QWINOUT three225 racing drone.
Now I have bind with the FS-I6AB I can not connect with the QWINOUT three225 racing drone.
Does any body have any isea how to re Bind to the racing drone as was pre bound when purchased.
Normally the receiver will have a button on it that you need to press sometimes press and hold till the led starts to flash to indicate that the receiver has been put into bind mode, then put your radio into bind mode and they should find each other
Hi, thanks for feed back, yes thats my thinking and yes there are two buttons one seems to restart the drone and the other causes a loud, high pitched tone and a couple of red leds to be switched on. Whilst all this is happening I have my TX sat in bind mode but no connection are established. My bet there is a protocal on the TX that has to be changed to bind with this Drone? Or a hidden jumper?
Best
FS-I6 FLYSKY.
Thanks for your interest.
Have you started a new model and bound the iA6B to that?
Nope I just put the TX into bind and the RX I put the jumper on to put into bind mode and they connected.
But then I found myself not knowing how to reconnect to the original drone!
This is for the Turnigy version, but it’s the same as yours
Can you take a pic of the rx on the drone. Or identify which rx is on the drone.
Thanks for the manual for the TX, however I think it the RX that causing the problems as I am unsure if it in Bind mode or not.
Bind button found, right at the back of the drone on RX PCB!!! Didnt know the function of the module, so now I can make the claim, not a beginner any more?
Thanks for support everybody
Nice one.
I was going to say there should be a bind button on the rx.
I would now save that drone in a memory slot then every time you mess with a new rx do it on a new model in a new memory slot.
