There are two ways to approach here. First is a very short walk from Buscot where there is a car park ///cowering.awakes.navy . Come out of the carpark on foot and follow the road north to the site. The easiest place to TOAL is from the field just south of the weir pond ///widely.coasting.move
You can also walk on through to the lock and weir along a small alley path just north of the pond along the track ///pound.tint.times.
The second way with a longer walk is to park in the layby at ///staples.regulator.pockets walk in to the entrance and right which will take you along and under the bridge on to the Thames path. Follow the path passing a WW2 block house along the way and it will take you to the lock and weir, total distance 1.8km. TOAL from the same location as the first route.
There is a backup TOAL spot if the the field by the pond is busy ///brotherly.helps.chicken where you should be able to stay well clear of anyone. It is a short walk over the lock and a bridge.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 02/04/2022. It remains the responsibility of any pilot to check for any changes before flying at the same location.
