A guy I know has a brand new build using a Caddx Vista and the Vista won’t power on. He has tried a different known working Vista and that’s not working either. When he puts the Vista in one of his old quads it works fine. I’m thinking dodgy flight controller? Any other thoughts? Oh and he’s using a T-Motor F7 Mini stack
Just wire it to vbat.
Yeah the vista will take upto 6s voltage so has he powered it from a VBat pad on the flight controller?
Thanks James, at the moment he is using the plug but is going to try hardwiring it after work. Will Vbat be ok? He’s running 6s
Ah thanks Deano, no he’s using the dedicated plug at the moment but he’s running 6s so hopefully Vbat will work ok if Vista can take upto 6s
Quick update* He has hardwired the Vista to the 10V pad on the flight controller and its worked straight away. Must be an issue with the plug. Cheers guys
