You can take a walk up from the House of Bruar just off the A9, or there is a small lay-by in the hamlet of Calvine for a much shorter walk, though the lay-by is often occupied by the speed camera van. Follow the road down under the railway bridge and there is a marked footpath for ‘Struan Old Kirk’. The path takes you down along past the River Garry waterfalls, across a field and over to the old church. You can either retrace your path to return, or continue on up the road by the church to make a loop. Nearest food/drink/toilets are at the House of Bruar.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 25/06/2024. It remains the responsibility of any pilot to check for any changes before flying at the same location.
