Just a thought here, I have a Mini 2 with a knackered gimbal and I’m wondering about the possibility of using the camera on the end of a wire dangling underneath the drone, so it could be lowered into places.
Any ideas about if it would be possible?
A wire?
It needs power and video feed back to the drone to transmit images to your device and record them on the SD card.
I’m sure the Mini2 would create a load of fault messages.
And if you were to find a means of connecting it fully, then the Mini2 would give other fault messages.
A 360 camera on a bit of string would do, Ash?
Wouldnt it swings about, around and around making the video unusable
Also, as @OzoneVibe says above the Mini 2 doesn’t like weight added and would enable payload mode
Limiting how high and far you can fly
Yeah, I was thinking it might not get past the faults. Ideally what I would like is a live feed from a camera dangling in the water, up to the drone, which would then transmit back to me in real time. You can probably guess what I would use it for.
Think you’d need to move away from hobbyist drones for that.
Bespoke video transmission/recording modules with a suitable camera.
Good luck!
Thanks. What about a live feed that you would have on an FPV? And then just detach the camera? Or this. https://www.flyingtech.co.uk/fpv-camera-gimbals/caddx-polar-vista-digital-fpv-air-unit-camera-kit-dji-fpv
I’ve already got this far.
https://vimeo.com/789548849/ec93dcf6fe
But it would be even better with a real time feed.
Just thinking I could try out the broken Mini 2 and if it works then mod the Mavic to take the extra weight.
Extra weight? it looks like it worked on that video unless you want to use a bigger camera.
My other question is, what if the camera or line gets snagged
No idea on “what” alternative kit would be best … just think something that won’t be throwing angry messages at you would be best.
Maybe one of these?
Wasn’t @Kirky looking at getting one a while back?
(Vimeo video is just buffering for me.)
Edit: Just downloaded the video. I guess “through the fishing net” is a deal breaker.
Yes @Earwig , I ordered one cancelled as I see it cheaper else where, then to find out the website was a scam of the cheaper one, so I gave up on that idea, would still like one tho.
It won’t get snagged. That’s the reason for the smooth torpedo shape.
I have a very expensive ROV (underwater drone).
But for this project it has to be less than 60mm across, to go through net.
I had a Gladius Mini before the one I’ve got now and it wasn’t very manoeuverable. I wouldn’t recommend it.
Thanks for that @ash2020 i shan’t think about another one then, some of the other models / makes cost grands ….
@ash2020 which package of the chasing you got if you don’t mind my ask.
That’s quality that one
