Hello,
I am about to purchase the Happymodel Mobula6 which is an under 30-gram drone with the battery but has a camera on it.
I assume there are no rules for flying indoors as it’s not airspace but if you are to go outside in otherwise restricted area (like outside your house or the park next to it with buildings close by) can you fly legally or it is treated the same as 2kg drone?
This might be a stupid question but i really have no idea.
Inside you can fly fine but outside you still have to adhere to the drone code and any local bylaws, and as for in the garden you still have to maintain distance from people and property as per drone code.
Hope this helps.
“Small unmanned aircraft” means any unmanned aircraft, other than a balloon or a kite, having a mass of not more than 20kg without its fuel but including any articles or equipment installed in or attached to the aircraft at the commencement of its flight
Most of the more restrictive requirements only apply if the SUA has a camera, so disable the camera and you can fly pretty much wherever you want up to 400ft, so long as it’s safe.
There has been some confusion and downright plain ignorance from some corners of the world where folk believe (and want to believe) a sub 250g can do anything and fly anywhere.
Tis only the registration thats different.
Cant wait till we’re piloting fruit fly sized drones bought from flyonthewall.com
Suppose it depends on wether it is classed as a toy or not.
Probably not going by the CAA definition.
Toys are products designed or intended (whether or not exclusively) for use in play by children under 14 years old.
The camera thing for sub 250g drones definately needs clarifying.
CAP1789 states,
But even if the unmanned aircraft is less than 250g in mass, they must also register themselves when it is:
• equipped with a sensor that can capture personal data (i.e. a camera or ‘listening device’), unless it is classed as a toy.
For whoops without an onboard DVR, they might have a camera but they cant “capture personal data”.
Hi All . .
I recently purchased a ‘SJRC F11 4K PRO’ drone . . . .
But viewing the legalities . . Due to it being over 250grms . . .
Felt I needed to join a club to get tips on how to use the drone and do it legally.
Whereabouts is the club based . . ? . . (I am living in Silverstone . . .)
What steps do I need to take to get flying . . ?
Looking forward to hearing form the club . . .
Regards, Tony
Hi All . . Done my test . . .40/40 . . First time . . .(Happy!!!)
Sorted ‘Operator ID’ and printed ‘Flyer ID’.
Just need to find a place to practice without breaking all those rules and restrictions . . .Doh!
Any recommendations in the Silverstone area appreciated.
Regards, tc542
