Can you still use Dji goggles if you wear glasses and can’t see “jack” without them?
Which ones we taking about? V1/V2 or the Newer 2/integra. The new ones have lens diopters, the ogs (v1/v2) “might” fit your glasses, but you can get custom lenses for them too
@GunjaFPV I am referring to the one which is compatible with the mini 3 Pro as in the pic below
I wear spectacles and without them everything is blurry
Yeah the integra come with diopters you can replace, the V2 (which would also work with the mini 3) have adjustable ones you don’t need to keep replacing. Check the specs and see if they cover your range for your eyes. I don’t think you could fit glasses in them (though don’t wear glasses (I’m lucky!), and only briefly used the v2s!)
Integra - “DJI Goggles Integra comes with 11 pairs of lenses ranging from -8.0 D to +2.0 D. You don’t need to wear your own glasses, and can install suitable lenses according to your actual viewing requirements.
If you require astigmatism correction, or if the provided lenses are unsuitable, you can purchase additional lenses and use the eyeglass frames provided to install them on the goggles.”
Goggles 2 “DJI Goggles 2 supports diopter adjustment from -8.0 D to +2.0 D, so that the goggles can be worn without glasses.
DJI Goggles 2 also comes with free eyeglass frames. If you require astigmatism correction, or if the goggles’ diopter is unsuitable, you can purchase additional lenses and use the eyeglass frames to install them on the goggles. The goggles are easy to use for different vision levels.
The diopter of the lenses installed to the eyeglass frames can be superimposed on the diopter adjustment supported by DJI Goggles 2.”
Thank you
