Hi : do anyone know if this battery plus for the mini 3 / 4 pro. Can be charge on the mini 3 / 4 charging hub . ? Or do I need something other charging device ?
Cheers .
Yes its the same
Am only asking . As a friend of mine had purchase one
On eBay …( perfect legit ). Does not charge on his hub . Just have flashing lights on/ off. instead charging up to 1-4 … so not sure it correct way of charging
It’s faulty.
The lights will flash in a code sequence
