Clee Hill Ruins - Added to FPV in West Midlands
Ruins to explore, hills to climb and / or fly.
A popular place but easy going.
A good view of the area from the top.
Check out the weather radar and the nats radar.
Watch out if you use crossfire near the installations.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 22/08/2021. It remains the responsibility of any pilot to check for any changes before flying at the same location.
Why? what happens? what frequency do NATS run on :thinking:
maybe a question for @Nidge
Not sure of the frequencies involved, but I had warnings when the drone was at ‘x’. When
i was in between the tower and the drone. I repeated it a few times :man_shrugging:
The air to ground comms frequencies are in the civil aviation band, 110MHz to 136MHz. If you’re using the legal Crossfire (868MHz to 869MHZ), you shouldn’t be of any concern.
Karl will have experienced issues from the Radar as that operates on 5608MHz with an input of 250 Watts into the antenna.
I knew you’d know @Nidge :clap:
Thank you :grinning:
I’ve flown here too @notveryprettyboy :grin:
I’ve not flown it, but been up there a couple of times on the bike when riding down to Wales and Cornwall. Need to head over there this summer. :slight_smile:
I’ve just added a new Take Off And Landing marker to this location @notveryprettyboy :slightly_smiling_face:
