This is tricky, be prepared not to fly depending on conditions and if you're using something other than a mini, the area for TOAL to comply with SSSI is not massive so people could be nearby. I was able to get there first thing in the morning in November, so nobody was around.
To fly at the cliffs but avoid the SSSI and/or hikers, note the small gap in the SSSI near the carpark. I set up at the end of that gap, flew through the gap out to open water. That was my passageway each time. I'm not sure if that was being overly cautious, but seemed like a good idea. I also did not overfly the cliffs at any point. With that being said, I had no issues.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 16/11/2023. It remains the responsibility of any pilot to check for any changes before flying at the same location.
