Just got an Avata 2. Coming from a Mini 4 pro which I would regularly fly from my garden over residential areas with VLOS. As I understand, because the Avata 2 is over 250g, I can’t do this.
Now lets say I did do this (disclaimer, i’m not going to). What would the consequences of this actually be? A fine? Drone confiscated? How would I actually get caught doing this, other than someone reporting me and then the police looking at my flight logs.
Having flown the Avata 2 in manual mode, in the countryside (with a spotter), I actually feel much more in control and aware of my surroundings compared to the Mini 4 Pro. Strange eh.
The Police are responsible for taking enforcement action when it is believed that the requirements of the law have not been met. Depending on the circumstances, this action could be taken against the operator, remote pilot, or both. Penalties range from warnings to the confiscation of drones and even imprisonment.
Interesting, so hypothetically the Aeroscope picks up ANY drone in its vicinity? How would the police determine if said drone has committed any offense, there must be a lot of drones in the area that it picks up? Im based in Yorkshire, not near any airports
Makes sense - But would the police be actively monitoring this 24/7? Or only in the event a Karen reports a drone constantly flying over houses?
They barely have the resources to turn up to a car burglary at your address, surely they don’t have enough resources to be actively monitoring what drones are flying in the sky and if they should or shouldn’t be doing so?
Any DJI drone made in the last six or seven years.
AeroScope range is around 30 miles / 50km.
Your DJI drone will be broadcasting its location and your location in real time. AeroScope records and logs everything so there is a lot of “after the fact” available.
DroneID also reports the drone serial number, the same serial number you activated when you signed up to DJI apps and permissions.
@jorrisbohnson - Get yourself an A2 CofC Richard - the Avata 2 being under 500 grams can then be flown under the same restrictions as a sub 250 gram drone but you will still legally need a spotter if you fly it FPV
So it’s safe to say, if you want to fly FPV over residential areas legally, you need to be under 250 grams.
If someone wanted to fly 250+ grams over residential areas with minimal risk of getting caught they would need something that doesn’t ping out the DJI drone I’d? like HD Zero, O3 air unit etc.
Flying the Avata 2 over residential areas will basically guarantee getting caught?
