I am looking at a close area near my home, which shows an unmarked areas round a small beck/river, can anyone please explain what these lines refer to, I am guessing at two options,1) contour lines, but not showing height above sea levels, or 2) a marked flood plain area, as they are shown all along the Beck / River until it reaches a major river source.
photo??
crystal ball out of batteries
Any clues?
Where?
Map Links?
Totally out of ouija boards here.
Enclosed an section in question taken from Drone Scene chart
The query is the continous dark line encompasing the Blue beck
As above, they are contours - every 10m.
Only every fifth has the value on it … so at 50m intervals.
Your area is pretty flat - so you might have to search a bit to determine the value of each of the ones between annotated contours.
In Drone Scene there’s also an “Elevation Tool”
If you click on that and then a location (or contour) it will tell you the height.
Clicking on the red dot (that I added) in your area gives a value of 20m (top left).
Also, in Drone Scene, there’s a location share button …
Using this, and pasting the link here, helps someone else know where your are referring to. “near my home” is less informative. ![]()
A link example to the location you are referring to …
Thanks very much for the explanation, it was the lack of numbers showing heights that threw me, will look again in more details, thanks again
