Crawford Bridge, so called because it carries the road from Spetisbury to Tarrant Crawford, is probably the best known of the many bridges that cross the River Stour.
it is a Grade 1 Listed building. It was built in the 15th century and widened in 1819, and has nine arches
Be wary of 2 low-strung cables crossing the river 10 metres from the bridge whose supporting poles are hidden in the trees which line the river banks
It’s a picturesque setting I’ve shot several times before from the ground – best timed for early morning misty conditions.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 09/06/2025. It remains the responsibility of any pilot to check for any changes before flying at the same location. Landowner permission may be required before taking off.
