I have downloaded Litchi and tested a pano with the Dji P4
width 360
columns 12
height 120
rows 4
nadirs 2
I’m not best pleased with the outcome and i need to fine tune the settings, but he nadir seems to cause quite a difference in the image. I need to lower the height from 120 to not capture the rotors.
Any other feedback on using Litchi with a P4 is greatly appreciated.
Tried to upload but it was too large and failed.
Tony, I was a bit confused by this part:
What bearing would the altitude have on prop visibility?
The height setting seen here in the Litchi app refers to the height in degrees of the camera gimbal not the drone altitude. Stting it just above 90° will hopefully not capture the rotors. As you can see I had it at 120°. Hopefilly try and get it loaded up today.
For what it’s worth (I’ll check next time I boot it up)
I use let it decide the settings and I’ve had no issue
23 photos usually
Restitched it without the images that included the rotors and scaled it down to be able to load here.
Mines set 8 columns 3 rows 114 degrees and 2 nadirs.
Upload your photo to Kuula or Momento to give us a better idea
