Finally got to use the Crystalsky with the Mavic Mini using the beta version of Litchi.
Only problem so far is that I can’t get it to change the videi format to PAL so a bit disappointing. I guess it’s mainly amied at the States so perhaps updates will sort it.
Why do you need to change the video to PAL?
Glad it works though
Access to 25/50fps.
I do wish they’d stop using PAL/NTSC nomenclature … it isn’t either since it’s not interlaced!
I don’t think I’ve ever used 25fps on anything before
Each to their own I guess
Some like it for 180 rule shutter speeds.
I’ve only ever used my iPhone with the Mavic Mini which means I’ve been forced to use DJI Fly app
As I use Litchi on the other drones it’ll be great to use Litchi on the Mini now too.
I’ll carry on using the phone on the Mini (portability n all that) but I’ll be switching to Litchi from today. Can’t beat that consistent familiarity regardless of what you’re flying
Let us know how you get on, I’m favouring the Fly option at the moment, hopefully the beta will get better
