To get here you need to exit the M4 at junction 40 and follow the signs for Goytre. Once you've passed through the village you should be on a narrow road through the forest. If coming from the South there will be a small lay-by on the left. Park here, cross the road and take the signposted path.(heading East). Lovely fl;at wooded walk with a gentle incline - stick to the main path and when the path splits you can take either but the more direct route is downhill. Not long after you will see a steep embankment and that is one end of the reservoir.
The originator declared that this location was not inside a Flight Restriction Zone at the time of being flown on 12/07/2020. It remains the responsibility of any pilot to check for any changes before flying at the same location.
