Cheers for that George, glad I’m not the only one it’s happened to. Haven’t had time to sort it out yet but I’m sure I’ll be perfectly able to bugger it up on my own. Anyway many thanks for taking the time to point me in the right direction.
No probs. Should have mentioned to all - as you’re dealing with Regedit (that controls guts of Windows), his video doesn’t mentioned but you should >always< take a backup first (once Regedit is running, just go File…Export… , call it something like RegBackup290419.reg (or similar) then at least you can just revert back to a working system again if things go t##s-up then just fire up Regedit again, go File…Import… done
WARNING!!! Make sure you have “Computer” highlighted …
If not, you only get a backup of where you are and the tree beneath.
Found this out the hard way once.
Thanks OzobeVibe, should gave flagged that up though when I fire it up it seems to default to root anyway
It tends to go back to where you last used it … so, yes, ROOT if never used before or used in ROOT last.
Run it in old virtual machine ;o)
