Hello I seem to have difficulty loading the dji assistant I’ve taken it off and loaded it back on. When I plug my new mavic mini via the cable the USB is flashing but doesn’t load my drone. I tried with my mavic platinum and spark nothing happens. Help
Have you got the correct Assistant for your Mini
I was trying to connect my Mavic Zoom to my Mavic Pro Assistant, it didn’t work
I had the same problem, I unplugged the USB and put it into a different port and it worked fine.
I have to use the cable DJI supplied cable for some reason all others fail.
Mavic Pro and MacBook Pro
