Iv charged my Dji battery turned it on plugged it in to goggles but they wont fire up has anyone ells come across this >??
I have a lead as to use a Lipo but not sure which kind is best i.e 4,5.6S ???
I struggled powering on my goggles battery yesterday. Realised I needed to have the cable plugged in first. And if it is the same as mine, it has to be inserted into the battery quite far, until there is a click. Then I could do the usual ‘DJI double click’ to power it on.
ok ill give it a go
Are your goggles V1 or V2 Nick? If they are V1 they take upto 4S input but if they are V2 you can use upto 6s
There V2 and I had the for sight to bring a 5S battery with me; tried the above but no luck hence maybe the connector in the battery or cable is shagged
What happens when you push the button? Any lights at all?
Sounds odd. I’ve never had that issue.
I always carry a spare and a lipoadapter.
Worst case get in touch with DJI for a replacement
