Developed to be placed on any boat, V-Line boat mode gives a birds-eye view surrounding the boat and the shoreline.
A new tethered drone system from Volarious enables DJI drones for boats. The system allows a commercial off-the-shelf, Mavic 2 drone to autonomously take off, follow, and land safely on small vessels . The drone can remain in the air as long as it needs, as it is powered by the tethered line.
I’m not familiar with boats, why would you need a birds eye view of where you are? Can’t you just look out of the window to see what’s in front of you?
Search and rescue. On water, for someone who is 1.8m tall (for example) the horizon is 3 miles away. But at 50m above sea level, the horizon is a distance of 16 miles away.
Or in other words, the area that a person can see is 28 square miles at sea. Whereas an area that a drone can see (at 50m) is 804 square miles. That is more than 28 times the search area than “looking out the window”.
Could have done with that on the Broads recently, couldn’t see a thing out of the windscreen every morning cos of the condensation. Ended up sliding the canopy off, standing up & dressing like an Eskimo
I can see it’s use in Search and Rescue at sea, especially if fitted with an IR camera - much easier to see a casualty in the water from a few metres up whereas at sea level they can easily be obscured by waves.
I can also see uses for a van mounted version e.g. crowd control at large events
