That option doesn’t show on my display. Is it excluded from the free edition?
What are you using (phone pc etc) ?
@Sparky Got it. Thanks to you I’ve learned learned how to operate Airdata at last. Now I need to learn how not to need it. The Mini is easier to fly except it doesn’t have you to control the pilot.
Thanks for your patience.
@milkmanchris I started with the phone but Sparky pointed me to the PC
Also when it’s going wrong RTH isn’t always the answer ![]()
@PitchFader Sparkywys has opened up the wonders of Airdata for me . Watching a 3d flight from field to tree to the ground has a peculiar fascination.
, just try not too have too do it too often !
@Sparky Funnily enough it was the first time I’d used RTH in earnest.
Do you have Care refresh?
@Sparky Afraid not
Would loss of GPS being upside down account for the odd “Find My Drone” behavior?
Yes if you look at the airdata it’s fine, but that stops recording when the props stop, and that would have been when the drone hit the tree and then it flipped upside down
You had 23 Sats whilst flying and 9 when its upside down
@Sparky Thanks. That’s worth considering. There’s a good chance that ‘find my drone’ will be no use after an incident so the flight log will be the first item I’ll use in any future search. I had a job finding the log tucked away in my profile.
Not necessarily, if you still have power in the battery & the drones still on ( your still at the scene ) & you then turn on flashing & beeping, you might find it / hear it before you have had chance to look at the Airdata, depending on how high or low your battery percentage is, it’s a race against time before the battery goes flat, then if no joy then go to the airdata, I’m only giving my opinion not saying I’m right or wrong, sorry for jumping in on your convo.
But like he said he didn’t know where the drone was, so followed find my drone that took him to the wrong location
The drone was upside down so giving incorrect GPS readings
Find my drone is not always reliable
I know as i experienced that, what I said in an earlier post,
using the find my drone with the google maps is rubbish but when I followed the straight line which was it’s last recorded location before it loses its gps or what it has saved so to speak within the fly app, that took me straight too the drone is what I was saying & worked for me & worked well, as the drone was screaming it’s beep the closer I got, me not like you guys in understanding Airdata, if that’s how or is easier to locate the drone whilst on the scene, then for those who know how to use it, that is probably a better option,
When mine had crashed, it was the last saved location that took me too it, not live gps, as it had already saved it …. I know that sounds confusing I know what I mean, sorry it’s hard to explain ![]()
Google maps are used every day by billions, there is nothing wrong with it
it reports the data it receives ![]()
It’s crap if you have no gps is what I meant, hence why that option of use within the fly app I was saying is rubbish / not accurate, without going around in circles the other method last saved location is not using live gps or misleading is what I meant ……
So before the drone losses it’s gps, I worked with what it had saved ( last location ) which took me too the drone, which is not using gps live but google maps does, when the map keeps updating through gps which it does, it sends you off course, hence why easier to follow the line in mine or that instance, also why he may have struggled to find it where the gps keeps changing / updating, I’m not saying it’s better than Airdata, or arguing the toss ……
