Hi there. Just at somones house setting up a DJI mini 2SE and dji fly says can not install on the phone we are using. Any ideas?
Dji directed to app store. Should i try to find direct from DJI (already looked and could not find. Has anyone got a link
Use this one:
https://service-adhoc.dji.com/download/app/android/3b03cb95-bc4b-4b62-b4ab-9cf977d77309
Misread that at first, I never knew MOTO had a services on the E20 lol
That link says "downlod again’ so i must have the same link.
Does it say “why” it can’t install?
Is the Moto e20 a 64bit device?
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-fly/dji-fly-1-4-8-release/
Open up the link scroll down until you see it, you might have to click next page.
Did you do it in this sequence Russ @Foley
I read somewhere a while ago when I rolled back my app ( don’t just click on other downloads that pop up )
So this
Then this
Then this
Not the easiest phone to work with
Looks like it will neec to be a 2nd hand phone.
The fly app needs 4GB Ram, that phone is not up to spec
Should check out which phones are compatible with DJI apps, not everything is simple and compatible to run this fly app, check out
Thanks for the advice. If anyone has a phone that is happy to run DJI FLY then will pass on the details. It is a DJI mini2se.
Russ
Would Litchi run on it?
