How does it sync? With my MA2 I have it side loaded to my SC. And on my Spark & mini 1 it was on my phone.
I take it just by my DJI login through the goggles?
Set up is all via DJIFLY on your phone tablet it’s a good hours job, that’s where you log in to your account etc, allow a good hour for this with all the updates etc.
To sync the Airdata you have to connect your phone/tablet to the goggles after flights and the logs will sync with the app then Airdata as normal, it takes a while though for it to kick in when you do it, the only issue is that everytime you connect to the app the FCC hack, if you are using it (it does make a huge difference)
Now I can take my time while out and about with the FPV drone. The charger will also charge the Inspire batteries too otherwise I’d have got the 120W boot charger just for the FPV drone.
Looks great, I came up with something similar that sits in a battery bag as I’m endlessly paranoid but the DJI gear is the only gear I plug in to charge and walk away.
Out of interest what is mounted or being carried under your drone?
