Dji fpv vision system connection error!
Thought I’ll have a quick go of my FPV and for some reason I now get a lot of error warnings regarding its vision system! It’s not been crashed, I have no idea what’s wrong with it, I’ve updated it’s firmware and tried the trick of switching off and on! Guess it’s destined for a trip to the Netherlands hospital under warranty :frowning:
Can’t find much on internet about it, anyone else had this issue? Thanks :+1:
Sorry can’t help.
Has a ribbon cable simply come adrift?
Are things like this accessible on the DJI FPV drone? :thinking:
Good point, it seems like it doesn’t recognize the whole vision system. There are screws underneath, so I could just take the vision system off to check with the Allen key, but then dji may say it’s been tampered with!
Check out 5:45 on this video:
Thank you, I just tried that, and put it back together and I get the same problem :frowning:
Guess it’s destined for drone hospital
What about trying the update again?
No it was knackered before the latest firmware update, that made no difference. Thanks though :+1::helicopter:
DJI are fixing it under warranty, needs a new sensor module and adaptor board :rocket::helicopter:
Had the issue myself the other day with the Avata however you also need to download the correct DJI assistant 2 consumer drone series app
Out of interest, mate, did the drone refuse to take off with that error in the vision system?
Hi @Guyblin, it looks as though you’re quite new here :wave:t2:
