DJI Geozones - reliability of
Please bear with me - and if I have been an idiot please tell me gently.
We’ve just stayed in our caravan close to a small regional airport. There was a nice area of flat saltmarsh nearby, so tried to launch the drone (DJI2S) but the interface said no take off here, which was fine and not unexpected.
The day after I walked 400 metres from this spot to the beach. The drone enabled, and I took half a dozen shots of the nephews playing in the sand from 20 metres up, and did a bit of autofollow on them as practise, again 20 metres-ish altitude, no higher than the sand dunes we were next to, and all within 50 metres of where I was stood.
I’ve just checked on Dronescene; where I was flying is marked up as a DJI Enhanced Warning Zone. More worryingly, it’s also marked as an airport, an airspace and a flight restriction zone on Dronescene. I wasn’t on any potential flight path, it’s the circular zone around the airport.
Was I stupid to rely on DJI Geozones by itself? I will always check with Dronescene from now on.
I feel like a right idiot to be honest.
Yes :grin:
Sorry if that sounds harsh but DJI “stuff” has no bearing on UK airspace regulations at all :slight_smile:
As per the CAA advisory publications it should be ignored at all costs.
yes
don’t rely on DJI.
the FRZ is to provide the airport with alternative approach / flight abort / routes should they have to undertake a come around (I believe)
it is a serious no no without approval at any height above the ground to fly, appreciate no drone police zone but it is part of the drone code
Unless you are over the Kings gaff
Here’s the document I’m referring to @Simon_Nonymous
And here’s where CAA recommend using Drone Scene:
Thank you all for your honest advice, it’s not harsh compared to the names I have been calling myself.
If it’s any consolation, the primary reason for us adding DJI map layers in to Drone Scene was to highlight just how bad their data is.
