Date: 2022.11.22
Goggles Firmware: v01.02.0000
What’s New?
• Added support to use with DJI O3 Air Unit.
• Added support to use Canvas Mode when using with DJI O3 Air Unit.
• Added hibernation mode: the goggles will enter hibernation mode after being idle for a long time
(approximately eight minutes) when powered on. Wake up the goggles by pressing the link button.
• Optimized the video transmission experience in broadcast mode for both pilot and audience.
• Optimized prompts in some scenarios.
• Optimized the goggles tutorials.
Notes:
• Restart the aircraft (or air unit), remote controller, and goggles after the update is complete.
• Note that the update may reset various flight parameters such as the RTH altitude and the maximum flight
distance. Before updating, take note of your preferred settings and readjust them after the update.
• If update fails, restart the aircraft (or air unit), remote controller, goggles, and DJI Fly or DJI Assistant 2
(Consumer Drones Series) and try again.
Date: 2022.12.08
Goggles Firmware: V01.03.0000
What’s New?
• Added support to use with DJI FPV Air Unit Module.
• Added support to use Canvas Mode when using with DJI FPV Air Unit Module.
• Added support for the following video recording specifications when using with DJI Avata:
• 2.7K@120fps
• 1080p@120fps
• 4K@30fps
• 2.7K@30fps
• 1080p@30fps
• Added ability to transfer data from the aircraft internal storage to the installed microSD card when using
with DJI Avata.
• Added ability to configure the sharpness and noise reduction value.
• Added ability to display the channel information on the LED dot matrix display.
• Optimized some interface prompts.
Notes:
DJI Goggles 2 Release Notes
Goggles V2 Firmware: V01.04.0000
Whats New?
