This morning after contemplating, I decided that since the Dji foam is completely useless, there was no point in not trying this mod and if it doesn’t work they’s always the anticipation of the new one to be released at some point by Dji.
I just haven’t been able to fly comfortably and without my eyelashes rubbing the lenses and smudging them.
Having bought the after market foam which is thicker and does keep my lashes away from the lenses, I took the bezel of the Dji face foam.
It’s worked a treat, the only snug is the Velcro strips glue isn’t man enough to not pull away.
I’m now thinking of using some UHU to glue the form permanently.
On the other plus side of things, I can breathe as normal by adjusting the third strap.
I’ll leave the goggles tight on the manikin to see if the Velcro strips glue will hold later, otherwise I’ll glue the bezel to the foam.
