hi,
I am flying my inspire with a big HDMI screen instead of running the GO app.
when i select auto focus mode in the go app and then disconnect the aircraft, the next time i use it the focus reverts to Manuel. also using the go app i can manually focus with the c1 button and the left scroll wheel however this does not work without the app.
is there a way to focus via the controller without the app?
also can i set the default camera mode to continuous auto focus?
thanks.
any ideas?
I can’t help you with this one @bob as I only ever fly with an app.
Any reason you’re not running with an app?
ok not to worry…
i find it easier just to use a Hdmi screen when travelling. its much brighter form viewing in the sun. it basically makes flying simple.
i also had issues with the app streaming the camera view…possibly because i am running an older drone firmware?
thanks
