The Inspire 2 goes back to before DJI had bought Hasselblad … so there’s still scope for a Hasselblad based camera and optics purpose made for drone use.
D-Log isn’t an industry standard, and colour space / gamma tech has moved on a pace for pro use.
Perhaps an Inspire sized drone with purpose built 8k camera that uses ARRI Alexa colour space and ARRI LogC Gamma, with a tailor made range of lenses.
The price for the base point of that would be getting up a bit, but should all be possible for less than the cost of a bare Matrice 300.
The inspire 2 has been used on so many high-end film productions that I’ve lost count. It’s still used in Hollywood when the DOP isn’t insisting on bespoke lenses for custom depths of field and framing. The Chinese were challenged by SMPTE to create a compact low cost flying camera system that could match or exceed the dynamic range and resolution of a standard ARRI Alexa Mini which is one of the film industry standards. Their response was the Zenmuse X7 coupled to an Inspire 2.
The Mavic 3 doesn’t even come close and is a toy by comparison. And when the production calls for real Alexas and Reds with Parfocal lenses to be flown they are more likely to be mounted on custom heavy lift octocopters. There will be an Inspire 3 and it will continue to meet the demands of the industry as fulfilled by the Inspire 1 and 2 models. Meanwhile the Inspire 2 will continue to be used until their motors become non serviceable. The TB50 batteries will remain in production as they are being used in the latest DJI Ronin 4D
It just reflects the way the industry is going/already gone… the bigger firms can afford it, the smaller firms will find it even harder to compete for broadcast work (if they ever had a chance anyway) as the barrier to entry is raised. The inspire range was a more affordable way (than Matrice) to provide broadcast quality output. I guess DJI have done their sums…
