DJI Mavic 2 Zoom sensor calibration issue
Hi Guys
I have an error that came up today to calibrate my vision sensors, went to DJI assistant to calibrate watched all the videos but as I am doing it, comes up with error i.e. aircraft moved resume calibrtion in so many seconds, just cannot seem to do it
Mark
Is it a laptop? Is the screen not dead-on vertical?
No it’s a large computer screen
As I rotate the drone it comes up with aircraft movement error ffs I need for tommorow grrrr
have you got the right version of dji assistant
have a look at this bloke doing it
if you move the whole drone it don’t work you just have to point it like it was on a tripod
Yes watched it over and over don’t get past first square comes up with movement error I’m thinking maybe better doing on laptop as my screen is a bit large what do you think ?
Got the correct version I hope as it comes up with Mavic Zoom ?
I had this two weeks ago, I was trying to calibrate it in the evening, had all the lights on in the room, adjusted the res down to 1080 etc but just had the same issues you are having.spent 2 hours trying.
Next morning in daylight with all blinds open it worked first time!
Just to add I was using a 32 in monitor
Thanks for that info @Scuba01 will try again this morning will let you know :+1:
Set up in alternative room ie more light and 1080 still same issues :rage:
Only next thing and is it possible to do on a laptop?
Any help appreciated
I’ve had that message for ages, it hasn’t affected the Mavic in any way shape or form. The only reason why I haven’t calibrated yet is because when I got the cables out to connect to the laptop, I find they were the wrong cables in the box. Also the wrong car charger. It would appear that the charger is for the original Mavic and presumably the cables as well. I’ve just never needed them before now. Anyway it hasn’t affected the flying or the sensors one jot, just a bit disconcerting seeing the message.
Yeh thanks @Brian on Go4 it says sensors NORMAL ? Weird but will try on laptop later hopefully succeed so ferking annoying :rage:
PS there was no cable that came with the Zoom to fit it I used my GoPro cable
Also the blue square moves erratically ??
Yes mine says sensors normal. Yet have an error message. I’ve been flying for months with no measurable effects on flying
That’s good to hear @Brian was a bit worried when I saw it come up, but hopefully get it sorted later
Thanks Mark
That’s what I’m doing, getting it sorted later.
Mine didn’t work on a 27 inch Mac but worked ok on my MacBook tried it last night
I found exactly the opposite to what the guy in the video is doing. Rotating the drone didn’t work but moving the whole drone keeping it square on to the screen did.
Hi @Brian well took all of 10mins on laptop so bloody easy after 2-3 hrs struggling on PC :rage: so alls good
I’ll do mine when I find a cable.
They say on YouTube videos one that came with your Mavic, I didn’t get one like I said used the GoPro lead, good luck @Brian👍
