DJI RC Pro Remote Controller Firmware: v03.02.0100
DJI Fly App: v1.10.0
What’s New?
Added D-Log M color mode for the Hasselblad camera.
Added support for DJI Goggles 2, DJI Goggles Integra, and DJI RC Motion 2. Visit https://www.dji.com/mavic-3/downloads and refer to the Consumer Drones and Goggles Compatibility Information for more information.
Fixed some minor bugs.
Notes:
Make sure to update the firmware of the aircraft, goggles, and motion controller before linking. The user can use DJI Assistant 2 (Consumer Drone Series) to update the firmware of each device individually, or use the DJI Fly app to update the firmware:
a. Aircraft: Update the firmware with the remote controller.
b. Goggles and Motion Controller: Power on the goggles and the motion controller. Connect the USB-C port of the goggles to a mobile device, run DJI Fly, and select Profile > Device Management. Locate the corresponding goggles. Select Firmware Update and follow the on-screen instructions to update the firmware.
Added features require DJI Fly v1.10.0 or later.
Camera settings will be reset after firmware update, check the camera settings in DJI Fly.
If the update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 (Consumer Drones Series), and retry.
I think those upgrades a pretty trick tbh, if & when I know mr @Sparky tech guru ( compliment btw ) you will maybe able to give me the heads up, If it doesn’t break my rc pro for the patch, I’ll be the tester AGAIN
Ok so in all fairness, I never really looked at the sensors of the mavic 3. However, I assumed they were sensors and not cameras. Upon receiving the update this morning, I looked closer and they appear to be cameras. Now it appears that I can change view and look sideways and also in reverse. Has anyone used this yet, how, and does it work well. For those who think I am mad, (more then normal) here is the message on my screen to confirm my reasons for this question.
Russ @Foley
Just thought I’d mention, reading a few posts on a DJI forum, how true I do not know, also more with the mavic 3 pro, has been a few moans of signal drop outs & a few other things, thought I’d let you know, again more aimed at the pro, not all but some
