DJI Mavic Air 2 - IMU failure error code 30050
Hi there i have just tried to start my drone after a few months of not using it and have got loads of error codes that i cant do anything with.
Its a mavic air2
Problems are
Problem with gyro code 30045
Barometer code 30047
Imu code 30050
Gimble 40012
Any help would be greatly appreciated
Sounds terminal, I take it you have removed and replaced the battery and tried again?
You can also try refreshing the firmware with DJI Assistant 2
Yeah, made sure its upto date but nothing has worked
Ah i will try that thanks
Try the firmware refresh
