Anyone know where the aerials are positioned on the Mini 2 drone? Looking for a safe position to stick an airtag
Assuming the 2 is the same as the 1, they’re in the front legs:
Front legs
Don’t people ever read the manual ha-ha… or just rely on others, which seems easier for them… bizarre… in the front right leg… hope that helps. Cheers.
Also might want to avoid the GPS, which is on top halfway down the body.
And the weight. Airtag is 11g or so?
And a gram or two for the sticky pad.
Is it heavier when omitting a sound?
No, it’s quite high pitched so must be a light noise. You’ll be fine
