DJI Mini 2 gimbal jerking
As above
I have searched this group and can’t find anything
Mini 2 in 4k at 200ft
When using the gimbal my screen shows the gimbal jerking as in goes up or down the scale in batches of four
Simplified turning the knurled dial the gimbal goes a qtr up the scale stops then another qtr same for down
At 0ft it was ok
Was this the wind as I’ve read you adjusting the gimbal whilst the drone is trying to level it in wind
Sounds feasible but is it
MM
Perhaps you can share a video of the issue whilst in flight. It may help diagnose the problem.
Will do I’m not only a new droner I’m also a new photographer so patience please I’ll get there :snail: :
How do I post vids on the group most are 5gb ish ? :floppy_disk::face_with_monocle:
MM
Upload to YouTube and share the link here.
This is the video regarding the gimbal,
Thanks Paul but no it’s not that vid that was me pressing buttons and seeing what happens
I’ll post a new video tomorrow
Thanks all
MM
God that sounded irresponsible I knew what the buttons did I was playing to see how it effects video
MM
is the camera in fpv mode? in fpv mode the camera is fixed to the movement of the drone.
Silly question (I’m renowned for silly questions), are you seeing the gimbal jerks in both the live video stream and the video off the SD Card?
The reason I ask, as you mentioned it was at a distance and not close in, could be due to signal quality. When at a distance and the signal is weaker the live video can stall, which would give the impression that things are not as fluid as expected. I won’t bore you with the details but there is a lot going on behind the scenes with the DJI link (compression, error correction, etc) and things can appear to slow down in adverse signal conditions.
Have you done a gimbal calibration
a video regarding gimbal settings (yaw)
