hi i have the chance of a mini 4 pro exellent condtion but was wondering if the batteries are okwith cycles of 31 27 and 25 thanks in advace
Don’t see why not, seen a lot higher
cheers for the reply
Should be good for 200+ cycles.
And not always how many times they have been used, sometimes they register a charge even if unused to the next charge
They’re Lithium-Ion Polymer - commonly know as LiPo and are good for 500 cycles - I use Lipo’s in all my RC planes and they’ll last much longer than 500 cycles but with a slightly reduced flight time once over this sort of threshold
As @macspite suggested, all the evidence I have read/seen says 200 cycles is about the point when the battery is on its last legs, so 25/27 is early days
Fair enough - but people get tribal about their particular brand of LiPo. for FPV racing, the key factor is voltage sag ‘cos volts = rpm’s = speed … but if you’re not putting big current draw on your batts (and DJI speed controllers ensure you can’t) it probably wouldn’t matter much … either way, 25 cycles is nowt!!
