Coming soon! the 4K Mini ![]()
Mentioned here a few weeks ago ![]()
@ianinlondon has one
For reference the MIni 2 label from the FCC database
@ianinlondon any chance of a picture of the label of the Mini 4K
Yep; here it is. Defo based on the Mini 2 SE body I’d say
But I won’t lie, I checked the Mini 2 SE specs but didn’t check the original Mini 2 specs, and if I had, I’d have said a bit more about this appearing to be a bit of a paint job on the old Mini 2, just updated to comply with C0 labelling (which is does have).
Same as the FCC database, they have labeled it as the Mini SE, but it is a clone of the Mini 2
I get why they’ve done this; updating it to comply with C0 requirements and just get pretty much their cheapest 4K drone out there for beginners. But it would be good for them to be giving us a new Mini 5 Pro or focussing on an Air 3 with a proper sized sensor… ![]()
I wonder if they will bring out a firmware update for the 2.5k mini se to 4k ![]()
The Mini SE is a 4K Mini 2 but with downgraded firmware, there is talk you can flash it with Mini 2 firmware ![]()
I’m still on my original mini 2 anyway. ![]()
Keep it and you can now call it a DJI Mini 4K ![]()
No front led on the 4k so def from the mini se ![]()
My Mini se2 had the n1 .![]()
You are correct it was the Mini SE that had the older style Mini 1 controller
