Only signal issue I have with mine is flying it from the phone (app) in sticks mode
It’s for seeing fish .. when you crash into the water .. obviously. ![]()
I also had issues with using the phone on its first flight - something to do with calibrations be needed pre-flight it seemed - again didn’t see this issue again as I basically only use the drone as a follow me auto thing.
Just had this appear in my FB feed.
I assume it’s the Neo 2
Very interesting, looks like a great little drone and will be available at Leicesterdrones.com of course (and don’t forget your discount!) Regards, Chris
keep up mate ![]()
What’s that in the first picture @SparkyFPV ?
Optional RID beacon?
Looks like shitty micro USB
Transceiver on the back of this drone allegedly created the necessarily Ocusync connection so you can use it with existing DJI remotes. Without, you can only fly this drone via short distance Wifi connection.
So they’ve ripped the gubbins out and stuck it on the back as an optional extra ![]()
Maybe, or it’s just a range extender ![]()
Or
Goggles N3 adapter
- Fly Solo Bundle: $229 (Neo 2 drone/1x battery)
- Creator Combo Bundle: $299 (Neo 2 drone/2x battery/RC-N3 controller)
- FPV Starter Bundle: $399: (Neo 2 drone/3x battery/Motion 3 controller/Goggles N3 adapter)
- Fly More Kit Bundle: $449: (Neo 2 drone/3x battery/Motion 3 controller/Goggles N3 adapter/case/charging hub/additional propellers)
As per @SparkyFPV said earlier -
Keep up ![]()
What the prop
