anyone seen or found the DJI O3 air unit CAMERA wiring/ pinout?
I am wondering if it uses s-video or cvbs … and if one can tap into it?
(not interested in the generic wiring for the whole air unit, just the camera)
thinking about trying to connect a second camera into the same channel
If you change a camera you have to calibrate it with the assistance software
I’ve heard that non-genuine ftom Ali wont calibrate
Never seen a wiring diagram
@Mads-Tech might have one
I was going to get a long camera to vtx cable and splice into it to try to work out what each of the cable cores do
I know it’s got a gyro, that will output back to the vtx so that gyroflow can function, hence… I am hoping that the cables will be…
vcc
gnd
tx
Rx
miso
mosi
cs
video…
the next issue will be if it is pal or NTSC or something else video signal wise.
I may just get another set of goggles and a different vtx arrangement that is more open (walksnail?)
