DJI O3 Air unit flight data
Afternoon all
Anyone know if it is possible to get flight data from o3 into dji fly or air data
Should it be jn my goggles 3?
Connect the goggles to the fly app and allow the flight data to sync to DJI then download it to airdata
I tried that and it didnt transfer.
I flew the avata 2 also and they have moved over. Got 122mph out of my first flight with self build and wanted data
Ill plug them in for longer
Oh you mean the O3 air unit
Sorry yes
Did you record in the goggles as that has the telemetry overlay
If it’s a self build you’ll need to add gps via beta flight or similar.
I’m guessing you must have something set up otherwise it wouldn’t show speed.
You’ll also need a good amount of satellites locked to be accepted as “real”
Then use the goggles footage osd to verify the speed.
This is the method I’ve used to provide submissions for our speed records.
I’m not aware of air units being able to provide data for air data. If there is I’d love to know as I’ve got 6/7 that will have some good data on.
Many thanks
I managed to get it from blackbox and your correct its in goggles overlay
