A thread to discuss firmware updates for the DJI O4 Air Unit
Overview
- Date: 2025.01.09
- DJI O4 Air Unit Firmware: v01.00.01.00
- DJI O4 Air Unit Pro Firmware: v01.00.01.00
- DJI Goggles Integra Firmware: v01.07.00.00
- DJI Goggles 2 Firmware: v01.11.00.00
- DJI Goggles 3 Firmware: v01.00.07.00
- DJI Goggles N3 Firmware: v01.00.03.00
- DJI FPV Remote Controller 3 Firmware: v01.00.03.00
- DJI FPV Remote Controller 2 Firmware: v02.00.11.00
What’s New
- Added support to use with DJI FPV Remote Controller 2 when using with DJI Goggles Integra or DJI Goggles 2.
- Fixed some minor bugs.
Notes:
- Restart the air unit, the remote controller, and goggles after the update is complete.
- If update fails, restart the air unit and DJI Assistant 2 (Consumer Drones Series), then try again.
Just updated my O4 Au, found I needed the very latest consumer drones 2 app on pc. Previous version did support goggles 3 but not O4… Other than that all good.
Saying all good! I believe beta flight osd compatible is available for use on I nav FC’s? I can not get any osd on the O4 pro as I can on the O3 system running goggles 3 with beta flight comp set up in OSD tab in configurator. Any help please…
Overview
- Date: 2025.03.06
- DJI O4 Air Unit Firmware: v01.00.02.00 ARB 0
- DJI O4 Air Unit Pro Firmware: v01.00.02.00 ARB 0
- DJI Goggles Integra Firmware: v01.08.00.00
- DJI Goggles 2 Firmware: v01.12.00.00
- DJI Goggles 3 Firmware: v01.00.08.00
- DJI Goggles N3 Firmware: v01.00.04.00
What’s New
- Added support for the INAV OSD feature when used with DJI Goggles Integra, DJI Goggles 2, DJI Goggles N3, or DJI Goggles 3.
Notes:
DJI have released an update for the O4 Air Unit (Lite & Pro models)
DJI O4 Air Unit Series Release Notes
Date: 2025.06.11
DJI O4 Air Unit Firmware: DJI O4 Air Unit Pro Firmware: v01.00.03.00
v01.00.03.00
What’s New
• Fixed some minor bugs.
Notes:
• Restart the air unit, the remote controller, and goggles after the update is complete.
• If update fails, restart the air unit and DJI Assistant 2 (Consumer Drones Series), then try again.
DJI_O4_Air_Unit_Series_Release_Notes_en.pdf (70.5 KB)
According to Ian (MadTech) this resolves the VTX MB rate issue with the Goggles 2 & Integra.
The issue (now resolved) was that the VTX power was limited to 15-16 mb when the Ham file hack was installed in the goggles.
Thanks for all the update details Jason ![]()
I’ve moved your post in to the main O4 firmware thread ![]()
• Date: 2026.01.19
• DJI O4 Air Unit Pro Firmware: v01.00.04.00 ARB 1
What’s New
Notes:
• Restart the air unit , the remote controller, and goggles after the update is complete.
Apparently this update, disables the capability of rolling back to previous firmwares.
So I’ll be staying clear of it for now.
Elaborate please?
Anti rollback value 1
You cant go any lower than the setting; the one before was 0
DJI uses ARB to stop hacks
