It exists ![]()
DJI O4 air unit
- Two versions: Lite and Pro
- 1/1.3″ F2.0 camera sensor: Better low-light performance
- Mounting Options: 20×20 and 25.5×25.5mm
- Dual Antennas
DJI to Introduce O4 and Race Mode
DJI O4 Pro
60Mbps 1080p Live view on Goggles 3 and Goggles N3 (50Mbps on G2 and Integra)
130Mbps DVR With D-Log M
SD Card/onboard storage
New Larger 1/1.3" Camera F2.0
Dual Antenna 33dbm Max RF Output
Latency as low as 15ms when used with Goggles 3 in Race Mode. 30ms latency on G2 and Integra.
Rocksteady 3.0
Betaflight & Inav OSD Support.
Size 33.5 x 33.5 x 13mm
31g Weight
O4 (known as the lite)
Single board PCB Design <10g Weight
1 - 3 S Voltage Input
60Mbps 1080p Live view on Goggles 3 and Goggles N3 (50 Mbps on G2 and Integra)
1/2 Sensor 14mm camera
Single Antenna with 30dbm RF Output
20ms Latency in Race Mode On Goggles 3.
26Gb Onboard DVR no SD card.
100Mbps DVR Normal Only.
Rocksteady 3.0
Size 30 x 30 x 6mm
<10g Weight
DJI is introducing a Race mode with lower latency than normal mode capable of 15ms on the Pro and 20ms on the lite when used with the Goggles 3 .
Race mode will only be compatible with Goggles 3 and Goggles N3.
O4 will also be single band 5ghz. In EU it supports both 5.2 and 5.8gHz and in US 5.8ghz only.
At launch O4 is due to be supported on Goggles 2, Goggles Integra, Goggles 3 and N3 however Race mode is only on Goggles 3 and N3. Bitrate is reduced to 50mbps and latency increases to 30ms when used on Goggles 2 and Integra on both Aiirunits.
Also final note Goggles N3 will also launch as a standalone this week but no stock as retailers and will ship a little later than the Neo packs that will be immediately available.
Enjoy
Mad
Well seems time to get the G3… How much are they…
Wow a racing VTX to go head to head with Walksnail!
Noice!
Watched Mads video on it last night, can say he has some strange friends ![]()
Any price leaks yet?
no nothing
One for whoops one for big quads at a guess. Smart move given the surge of whoop pilots recently.
All hell will break loose when they announce none of the current goggles are compatable and some new ones will be coming out to work with the new air unit ![]()
standard DJI that one, give it 3 months and then backwards compatibility comes in to further disappoint those who invested early.
Been caught out by these pesky tricks too many times
All hell when they say the O3 is not longer available
These thing not going to be 4k then ???
Hmm…… carbon FPV frames next ![]()
The DJI O4 Air Unit Series marks a new leap in video transmission performance, delivering a cutting-edge digital video transmission solution with higher resolution, lower latency, and extended range. Weighing
just 8.2 grams, the DJI O4 Air Unit features a 1/2-inch image sensor capable of capturing 4K/60fps video, offering both portability and versatility. Taking it a step further, the DJI O4 Air Unit Pro boasts an enhanced imaging capability with a 1/1.3-inch image sensor, capable of recording 4K/120fps video. It also supports impressive features such as 10-bit D-Log M color mode and a 155° ultra-wide FOV, capturing the vast expanse of the world in unparalleled detail.
The DJI O4 Air Unit Series is equipped with the DJI O4 video transmission system, achieving ultra-low latency for more responsive controls. Paired with the dual-antenna design of the DJI O4 Air Unit Pro, the max transmission distance can reach up to 15 kilometers, and the system can automatically select the most stable frequency. Whether soaring over mountains and rivers or navigating indoor spaces, you can perform confidently and with precision.
The DJI O4 Air Unit Series is capable of recording 4K/60fps video. The video transmission system utilizes H.265 video encoding, supporting high-frame-rate transmission at 1080p/100fps, ensuring clear and smooth real-time imagery. No matter how fast you fly, the camera view keeps up.
The DJI O4 Air Unit Series introduces a new Racing mode, with video transmission latency as low as 15 milliseconds. It supports up to eight aircraft racing simultaneously, taking you on an exhilarating, high-speed journey through the skies.
