DJI RC Pro quick transfer to iPhone 16
I am trying to connect my iphone 16 to my RC pro to see the files on my, it connects ok but when i go to exit on the exit quick transfer screen it says “exited successful” the screen on the RC still has the quick transfer screen loaded and will not clear as it normally does. I turn everything off to reset it.
The phone wifi and bluetooth are connected to the drone. I have tried replacing the fly app on my phone but no difference.
Use USB-C to the controller to the Phone then use the file app on the phone and you will see the device listed there. Then you can view the files on the device.
know it don’t fix the issue you have - not sure why it does that but it might be that you do the quick transfer from the drone to the phone and not from the controller ?
Thanks, I am not sure why it has started doing this :frowning:
It’s because it’s a new phone, have you an older phone to test it
I just tried the to do it with my RC controller and it worked fine, looks like the fly app on the RC pro is corrupt.
Factory reset maybe ?
Not sure why you would want to quick transfer from the controller as the files on the drone are way higher quality than on the controller.
Even of my Mini 3 Pro to phone I hardly ever use it as its a bit slow - easier to just take the card out and put it into a reader into phone or laptop.
I am using it to use the DroneTweaks app and its part of the workflow.
I am just backing up the controller and going to try a Factory reset
All sorted I did a factory reset on the controller :smiley:
