DJI RC2 Controller problem
When i a flying my mini 4 pro my Controller sometimes jumps back to the go fly home screen without touching it and i have to tap go fly again to get back onto my main flying screen
Hi @there, it looks as though youâre quite new here ![]()
Can you share a screen recording of this happening? However, I do suspect you are inadvertently touching the home button, top left of the screen
Hi Louishuey,
Despite what SparkyFPV suggested, if itâs any consolation, I have the same trouble with my RC2 controller. Itâs particularly and irritatingly prevalent at the start of a flight but can happen at anytime. The flight isnât interrupted but I keep having to press the go fly button to get the screen to function again. Itâs more an irritation than a serious problem. Software updates do not resolve the problem. Sorry not to be able to offer any solutions but at least you know youâre not alone.
On a similar note, when I fly a waypoint mission, I also get a random âObstacle detected. Waypoint flight suspended.â warning message for no apparent reason. Flying at 120m, no giant sequoias lurking in the shadows, no low flying Santa sleighs or pterodactyls.
I too get kicked back to the previous screen - RC2 controller and Mini4 pro.
I think the problem is my left-hand thumb just touching the top left corner of the screen as I go for height using the joystick.
I tend to rest my thumb on the controller casing while flying, and use just my thumb for controlling the drone, rather than hold the joystick between finger and thumb.
I am considering making some sort of âski-jumpâ rest that sticks to the edge of the controller screen (not on the screen itself) and seeing if that resolves my problem.
This problem happens for me despite many controller upgrades, and any drones attached to my RC2 controller, so I think it might be the human touch - in computer terms âdigital interferenceâ.
I have the same problem, put it down to me catching the edge of the screen with base of my thumb. I donât think the controller is designed for people with big hands. I donât get the same problem with my smart controller where the gap at the side of the screen appears marginally bigger. I also have a habit of accidentally pressing the C2 button. ![]()
Iâve had the same thing happen with my mini 3 and I am sure that it was a case of big thumbs rather than a technical issue ![]()
Hello
Apologies if this question has been asked before.
Mini 4 Pro and RC2 controller.
After take off, the screen goes back to reconnect drone, after which, the screen goes back again to reconnect drone.
I can still fly the drone but can`t see the recording. There is also a loud beeping noise like parking sensors. If I turn off the obstacle avoidance then the beeping goes away.
Firmware is updated and I have replaced the blades. I have not ever crashed the drone,
Many thanks
Stuart
Try disconnecting the drone from the controller and rebinding to see if that resyncs them together again ![]()
Moved your post to this recent, pre-existing, thread that seems to be about same issue. ![]()
Looks like I have Thumbling thumbs. Thanks
